跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Faulty board component replacement
I have a 2017 13” MBA that will not power on. Visual inspection shows no liquid damage, and the liquid indicators are still white. There is a component, R40G L27F, that seems to have leaked its contents onto itself, but not onto the MLB. I haven’t been able to find this part by the code. Is this likely what the problem is?
I’ve also checked the I/O board, and it doesn’t seem to have blown a fuse, at least by sighting it alone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is a induction coil nothing liquid inside. The shell is compressed Iron dust what you are seeing is rust!
The liquid markers don’t always tell if the system was wet and in many cases I’ve seen condensation being the cause.
People forget when they are in a humid climate and they exit a nicely cooled office or home the cooler surfaces will act as a magnet pulling the moisture out of the air! Just like a cold can of soda sweating!
So… Lets see if we can figure things out. What is the color of the MagSafe plug Amber or Green?
这个答案有帮助吗?
得分 2
3条评论:
MagSafe plug goes green, regardless of whether the battery is connected. There doesn't seem to be any burning around the fuses on the I/O board either, so I think I can rule that out.
完成的
@jaknz - If you had disconnected the battery and plugged in the MagSafe alone the LED should have gone to Amber. This points to a logic board issue for sure,
Time to fully remove it and make a detailed inspection. Often I see the back side has gotten wet. Use a good magnifier (board inspection microscope) to review the board.
There will likely be a point you'll need access to the schematics and board view drawings to trace out the power rails if you don't see anything visually.
This might be a good point to stop and if you have someone local who has deeper skills or look for a replacement logic board.
完成的
That's the point where it's probably beyond my ability to diagnose and repair, but I do have a repair shop I've used before that does MLB repairs. I'll probably end up just taking it to him to check. Thanks for your help!
完成的
添加一条评论
添加你的答案
Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 21
总计 176
