跳转到主内容
Happy mac chime but the screen is black completely, Please help
I have a pristine MacBook Pro mid 2007 15” A1226 2.40ghz with NVIDIA GeForce 8600M GT 256 MB. I hear a chime but no video, i have tried smc and pram reset and nothing works. I also tried booting it off of the original Mac OS X and the screen does not change just black, but no lines. I took it apart and i cant see anything broken or loose. I can’t figure out what’s broken in it, Please help.
Thanks,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What happens when you plug in an external display?
完成的
When i plug it in a external display the screen is remaining black, and fans come on at full.
thanks for the suggestion, wish this was a easy fix
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly there is not much you can do here as this series had two issues as I outlined here: Why is the Nvidia gpu failing?
Sometimes you can get a bit more life out of the system by using a rework heat gun heating up the chip to cause the solder joints to reflow. This is a 50-50 gamble! And you do need to be careful you don’t over heat things.
Frankly, given its age its not very useful as you can’t run newer (safer) OS’s and the version of web browser it has won’t work on many web sites. Let alone lack of availability of parts.
这个答案有帮助吗?
得分 1
3条评论:
Thank you for solving the problem with my MacBook Pro , I still like non unibody Mac's though so I may try a reflow like what you are saying.
Thanks for helping,
完成的
Here's a bit more on the NVIDIA GeForce 8600M GT MacBook Pro (Nvidia 8600M) GPU/Video Failures
完成的
Thanks for the info, also a bit scary that they can fail from heat (currently using Mid 2007 MacBook Pro 17").
完成的
添加一条评论
添加你的答案
macexpert1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 86
