跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
249 个问题 查看全部
Why does my screen turn black when opened all the way?
when I open it half way I have no problem with the screen, but when I open it all the way the screen turns all black but every thing else functions well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
I say it looks like either your graphics card is bad or the connections in the screen may be loose or need to be replaced. Or try and see if you can boot in safe mode by restarting then immediately press and hold the Shift key as your Mac starts up, then release the key when you see the login screen.
if your tech savvy you could take it apart and see if the cables are loose or damaged, if safe mode does not fix anything.
Hope that helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lehoo Kenny 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 40
过去 30 天: 163
总计 545
