跳转到主内容
Does the Glass Back Cover Adhesive need to be replaced on reassembly?
Hi there,
I was about to take my OnePlus Nord back cover off to test something with my vibration motor and realised that I might have to replace the adhesive when putting things back together. I am new to taking phones apart that use glue, so I wasn’t sure how this would work, especially since the Nord doesn’t require a heatgun to remove the back.
Do I need to replace the original adhesive before putting the rear cover back on, or does it fit back together without doing that using other connectors or possibly the original adhesive?
thanks,
Yannick
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Would recommend getting adhesive for water-resistant but you should just be able to slap it back on if you really need to
这个答案有帮助吗?
得分 0
1条评论:
Hi @consistent ,
Thank you for your answer. I do actually need it to be water resistant, because I use my phone a lot on my motorbike.
Would you say removing the adhesive with acetone and then using one of these to put it back on would work?
Tesa 61395 Tape
Polyimide Tape
Do you know what type of adhesive or glue would be best and also keep the water resistance?
Thank you!
Yannick
完成的
添加一条评论
添加你的答案
Yannick 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 25
总计 296
