跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Sleep/Power Button and Volume Controls won't work after a repair
my ipod needed a new battery, so i took it to the "Fix-a-Phone" in my local shopping mall, after the phone repair "Specialists" replaced the battery, i tested all my buttons, and the Volume Controls as well as the Sleep/Power button were non-responsive, i asked the guy who fixed it about it and he said he couldn't help me because he didn't even go NEAR the buttons, i called a BS on that and now i don't know what tool(s) to fix this iPod P.S. I NEED TO HAVE IT FIXED BY CHRISTMAS 2011, HELP!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
He severed the flexicable that is right next to the battery. Talk to his manager and demand it be repaired by a real certified tech instead if some kid at the mall kiosk. If that gets you no where call the techs at Atlanta Cell Tech at 404-831-0399 and ask them about scheduling a repair.
这个答案有帮助吗?
得分 2
添加一条评论
I myself just completed the same task that you've asked about and its not a job for the faint hearted. If you want to give it a go you'll need a new volume/on-off flex about £6 off ebay. You will also need the plastic tools to open your ipod complete with the sucker, a heat gun, a soldering iron, solder, solder mop and a very small philips screwdriver. I would recommend de-soldering the battery before going any further to help prevent you shorting your ipod. After that you'll need to completely strip the ipod down (i.e circuit board, battery and both camera's out).
这个答案有帮助吗?
得分 1
1条评论:
P.S.
Use the ipod teardown tutorial thats on this site to help you with taking it apart and re-assemble. Hope this helps.
完成的
添加一条评论
sell it on ebay...they are all broken on there ..
这个答案有帮助吗?
得分 0
1条评论:
it's really not a good answer. Anything else you might want to add to it, something that is more productive?
完成的
添加一条评论
Oh oops, sorry everyone I just remembered tha it isn't an iPod g4 it's an iPod g3, sorry I wasn't thinking correctly when I asked this question, can someone tell me the process for an iPod g3 for this same problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Carter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,207
