跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
How to remove heatsink
What type and size of screws hold the heatsink in place?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Can you give us a bit more here. Why are you taking the heat sink off, did you loose the screws?
完成的
i want to change the thermal paste but im not sure what size and type of screwdriver i should buy to remove the heatsink @danj
完成的
添加一条评论
1个答案
已选择的解决方案
Apple uses a collection of Pentalobe and Torx screws. The best thing is to get this tool kit Pro Tech Toolkit it will have everything you need. If you are just interested on the discreet drivers at the bottom of base page MacBook Air 13” Retina Late 2018 Repair guides lists out what you’ll need.
But before you proceed I would strongly recommend you get a goods baseline on what you are currently seeing for thermals. I sue this great app TG Pro getting the full version will offer logging which allow you to track things quite well.
You should also clean out the dust and debris using a soft paint brush and a can of can’d air to blow way the loos stuff in short blasts before you go into refreshing the TIM. One of the biggest issues I see is people over do the paste! Take a piece of single ply tissue paper that’s the size of the black silicon chip now wet your fingers and make a tight wad out of it, even that is too big a pea sized blob you’ll need! Even still don’t exceed it in size. HEre’s the guide to follow MacBook Air 13” Retina Display Late 2018 Logic Board Replacement
Lastly, you may want to monitor your memory and drive space as you maybe just exceeding what this system was designed to support.
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.图片
产品
Pro Tech Toolkit
$74.95
这个答案有帮助吗?
得分 1
2条评论:
i successfully changed the thermal paste the screwdriver that i needed was torx t3. The original thermal paste was like hard rubber not like paste. Now my cpu and gpu temperatures to 8 to 14 degrees celsius lower @danj
完成的
@hailo17 - Thats great! Don't forget to score the answer and accept it - Thanks!
完成的
添加一条评论
添加你的答案
Hailo17 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 875
