跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
113 个问题 查看全部
No power after logic board swap
Hello! I have a macbook pro M1 that had a bad logic board, making a popping noise when plugged in. I have replaced the board, and am still getting no power. The popping noise stopped, but I am not sure where to go from here. I have ensured everything is plugged in, and I am sure that nothing is missing. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Is voltage getting to your board at all? Is the board drawing any current?
完成的
What is the easiest way to check that?
完成的
I have checked the voltage, it is drawing the following: 5.16V, 0.05A, and 0.25W
完成的
添加一条评论
2个答案
已选择的解决方案
After randomly disconnecting the display, the computer booted as normal. I shut it down and reconnected the display, with the computer booting again. The battery is shot though and I will be replacing it. Thanks for the help everyone!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Did you replace the married TouchID power button that came with the replacement logic board? That is a must!
Frankly, I would have checked to see if it was still covered under warranty. Even still I would have tried to get a warranty exception for this issue as something is not right!
这个答案有帮助吗?
得分 1
3条评论:
I did replace the button, which came with the new board. The original board is water damaged, and also is out of warranty and given to me by a friend.
完成的
Being water damaged also adds more to the puzzle. Sadly, we just don't have much on this series yet. So probing voltages on the logic board (power rails) is iffy without physically tracing the pathways. The M1 MacBook Teardowns: Something Old, Something New is all we have here. I would recommend you look on the web to see if something has fallen off the back of a truck yet ;-}
完成的
I also tried it without the battery plugged in, same power draw. Think replacing the battery would help?
完成的
添加一条评论
添加你的答案
Philip Doherty 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 142
