跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Data Recovery from MacBook Pro 2017 13.3" Solid State Drive
So I did the worst-case scenario of pouring an entire glass of red wine on my macbook keyboard. The machine is totally friend, but I was able to remove the SSD drive from the case.
After a lot of research, it seems like people are having a lot of trouble finding adapters or external enclosures to access to file system on the storage drive.
Has anyone had any success in removing files from ~2017 era Macbook Pro SSDs?
Wanted to ask before I go to the apple store or use a third-party recovery service. Attached is a photo of the removed drive with model number:
Macbook Specs:
MacBook Pro 13.3" - Mid 2017
Model #: A1708
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly, Apple’s SSD’s use a custom connector setup, which OWC did offer external cases for the older MacBook Pro blade SSD’s, I haven’t seen any of the 16/17 Fn key systems.
The best you can do is find someone who is willing to allow you to swap-out their SSD with yours so you can then access the data making a backup onto an external drive. You might find a used system to achieve the same thing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Bender 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 315
