跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
Battery not working at 100% charge
I recently replaced my MBA’s battery. (Around a year ago with an iFixit battery). The OS says the battery is at 100%, but when the device is unplugged from power, it immediately shuts down. No battery indicator appears when I hold the power down for several seconds.
This is a new issue, it worked fine before. I have reset PRAM, SMC, unplugged battery and made sure that it is seated correctly. I have attached photos of System Info. Please let me know if there are other troubleshooting steps I can take, or if the battery is shot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Have you checked the driver/drivers for the iFixit battery that you used to replace your faulty one with? It is probably a software issue.
这个答案有帮助吗?
得分 0
6条评论:
Where would I find this driver?
完成的
@bitflip @cacciatore98762 - No drivers here! Just like a flashlight you just slide in the new batteries.
But it would be helpful to to get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
Make sure you have the MagSafe plugged in and give it a few minutes before you take the snapshot.
完成的
Well, considering that this replacement battery is an iFixit battery for your model of laptop, it is possible that you need to install, reinstall, upgrade, or repair the battery driver that is hopefully installed on your Macbook, so that the replacement battery can do what it is suppose to. After doing a little bit searching on the Internet,m I cannot find an exact driver for your laptop model that is a genuine driver for this battery. I would probably suggest that you search how to find the hopefully installed driver on your computer, and install, reinstall, upgrade, and or repair that particular driver either by using the Update software on your computer, or by copying and pasting the name of that driver into your Internet browser and go from there.
完成的
Thanks, @danj! I have added a screenshot of CoconutBattery.
@cacciatore98762 I agree with Dan. I don't believe it requires a driver because the battery should power the device whether an OS is installed or not, which this particular battery isn't.
完成的
Okay cool! I thought it was a driver issue. I want to learn more about this CoconutBattery software that @danj is referring to.
完成的
显示更多的1条评论
添加一条评论
@cacciatore98762 - OK, if you pull the MagSafe charger connection now, tell us how long it stayed running (watch some YouTube vids).
If it runs out in less than 2 hrs then you'll need contact the iFixit store to get a replacement battery.
这个答案有帮助吗?
得分 0
1条评论:
Great, thank you. I pulled MagSafe and it immediately shut down, as if you pulled the plug on a desktop. I'll have to contact iFixit Store.
完成的
添加一条评论
添加你的答案
Bitflip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 76
