跳转到主内容
加入维修社区 - 创建账户
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
Charging light won't turn on but the psp functions
Hello,
So I have this problem, when I plug in my psp, the charging light won't turn on, and it sometimes turns orange for a moment then turns off again. the psp is fully functional and I can turn it on, but it has no batteries detected. I want to know if it's the psp's problem or the battery??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
try cleaning the usb port
https://www.youtube.com/watch?v=GIoTlY1W...
这个答案有帮助吗?
得分 0
1条评论:
I did, it didn't work
完成的
添加一条评论
Be sure to use the ac charger and not the USB. Without a “risky” hardware mod to bridge the 5v pin on the usb port to the charging fuse, the USB charging feature doesn’t work as well as it does on modern phones meaning not at all sometimes. If you are using the ac charger and not the usb port and neither of those ports are dirty then it’s possible the charging fuse on the motherboard blew. It’s located right next to the battery connector that plugs into the motherboard and it’s very small. To replace or fix properly would require really good microsoldering skills. You can check if it’s blown with a multimeter in continuity mode. If it beeps it’s fine if not then it’s bad and needs replacing. This image shows where on the motherboard that fuse is located.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sideswipe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 953
