跳转到主内容
谷歌第三代 Pixel,是谷歌首款"刘海屏"手机。配备了一块 6.3英寸 QHD+ OLED 显示屏,内存有64 和 128 GB可选。三款配色分别是(差不多)白,(就那么)黑,(不算太)粉。
78 个问题 查看全部
After battery replacement finger print sensor stopped working
All instructions followed to replace battery with Pixel 3 XL. Fingerprint sensor cable was last connected before closing the back cover with adhesive applied. Now the phone no longer shows the Pixel Imprint option to enroll the fingerprint. Any suggestion?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi,The fingerprint sensor is very fragile you may have broken it during your repair.You could replace the fingerprint sensor or take it to a local repair shop for a diagnosis
这个答案有帮助吗?
得分 0
2条评论:
Dear FIXIT:
Any suggestion to diagnose this issue? or it's safe to assume that if Pixel Imprint function/option is not showing up in Security Setting anymore then I probably had broken the Fingerprint sensor cable somehow during the battery replacement process?
Appreciate your further comments.
完成的
Hello! Did you manage to figure out this issue? I am facing the same thing after replacing my battery and daughterboard. The fingerprint sensor and its connector don't show any physical signs of being broken (but tough to say how fragile is very fragile :-D ). Did you solve the issue by replacing the fingerprint sensor? I am trying to check all the boxes before I order a replacement and go through the entire back panel adhesive extravaganza again.
完成的
添加一条评论
Hi, same problem here. I think Ifixit should take a look because selling the batteries they should advice on how to avoid this to happen because it has happened to several people as I'm reading everywhere. In the tutorial you posted to try the official google fingerprint calibration tool which only work for pixel 6, 6 pro and 6a.
这个答案有帮助吗?
得分 0
2条评论:
Same happened to me after changing battery on Pixel 4a
完成的
Même problème pour moi. Je vais essayer de changer le capteur d'empreinte
完成的
添加一条评论
添加你的答案
CharlesCW 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 1,082
