Tried installing radio, now no radio, or accessories unless key is in.
Okay, so I have a 2003 Mitsubishi Outlander 4 banger, I previously installed a aftermarket radio for my mom in this car and about a month ago the cd reader stopped working, so i got her a BOSS radio single bin, i installed the radio and it turned on for a few minutes but noticed there was no sound… so i unplugged it and checked my wires and i wired it back exactly the same. The radio turned on for a few seconds and then it said “goodbye” on the screen and shut off. I got a little frustrated and decided to go inside for a few minutes. I took the key out of the ignition and went to lock the doors and they did not lock… then i realized that the hazard lights would also not turn on, then the headlights… nothing works UNLESS, you put the key in the ignition and put it in the on position. I have checked all the fuses I could think of, I swapped around relays and its still not working at all now. Any help would be very appreciated.
so, everything works with the ign on. What happens if you disconnect the BOSS radio? And reinstall the old radio as it was?
由 bill 完成的
@ruggb havent done that yet because the old radio had no harness so i spliced into the wires, gonna see if the old radio will turn on tomorrow morning
由 Aesthetic_Pat 完成的
