跳转到主内容
加入维修社区 - 创建账户
便携式电池供电蓝牙扬声器的维修指南和信息。
Ion Bluetooth speaker won't stay charged even after 8 hrs
Ion Bluetooth speaker from Walmart won't stay charged even after 8 hours of charging with no use , unplug for a minute and it dies. Will work while plugged in but that's it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I Have A Ion Bluetooth Speaker From Costco
When I Charge My Speaker It Stays Charge
I Don't Have Too Charge For Weeks.
I Play My Speaker Everyday And Can Charge My Phone
Conga Master
完成的
My Bluetooth speaker will work plug in the wall but I unplug it will not work has to be plugged in all time
完成的
@detrickmarshall
What is the make and model number of the speaker?
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Given it works when plugged in but not on the battery only, it appears as though the battery is faulty or has failed and needs to be replaced.
I cannot find a teardown video online that shows how to open the speaker, but here’s a link that may help in finding the correct replacement battery.
According to the link, if you have had the speaker for <90 days from new, then the battery is covered by the manufacturer’s warranty.
这个答案有帮助吗?
得分 3
1条评论:
Thank you, I just came across it myself, just before checking here. Again thank you
完成的
添加一条评论
I have to replace my battery. Want to know if the Ion Bluetooth speaker charging system works with lead acid batteries & lithium.
这个答案有帮助吗?
得分 0
2条评论:
Mine powers on but won’t connect to Bluetooth only radio any suggestions besides replacing the battery which I did but the company sent me the wrong size
完成的
you need to download the app and connect to bluetooth thru the app. THEN connect to audio via phone bluetooth
完成的
添加一条评论
添加你的答案
Chris Marques 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 10,288
