跳转到主内容
Nintendo Switch Joy-Con 控制器的维修指南和信息。
identify damaged SMD component
Hello everyone,
my Nintendo Switch sufferd by the flood in Germany this Year.
I try to repair the Joy cons. Because the Accupackage was still under Voltage a SMD component(I guess its a capacitator) sufferd from the electrocorrosion.
I cant measure its value anymore, so maybe someone can help me with this
Its in the lower left corner, maybe a boost capacitator.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That’s a coil not a capacitor, it’s should have continuity from 1 side to the other like a fuse but it shouldn’t short to ground.
这个答案有帮助吗?
得分 2
2条评论:
Ok thats a good info, do you know its value?
完成的
@wasserollum I’m not sure but it looks similar to the switch lite backlight coil
完成的
添加一条评论
添加你的答案
Oliver 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 224
