跳转到主内容
Repair manuals and information for the Microsoft Surface book line of laptops.
207 个问题 查看全部
Loose contact between screen and base (is it the base or screen?)
The base unit keeps disconnecting and connecting from the screen unit all the time, even if I do not move the book at all. Thus, an external mouse hangs or monitor gets black for several seconds. Also, there is a plug-off and plug-in sound of Windows all the time.
I have tried to clean the connectors on both sides with alcohol already, to no avail.
How can I identify, if the base or the screen is the culprit? If I had a replacement base, I could try it.
It seems that this issue also causes blue screens because when I use the screen only, there was no BSOD, yet.
Do you have any hints for me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would first use a small paint brush in the rails that the connectors are inserted into to remove all the dust. If this fails, then I would order a replacement base that is compatible with your model of surface book, then you can return it if it doesn’t fix the problem. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marcus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 304
