Bowers Wilkins A7 connection issue
I have a Bowers Wilkins A7 wireless speaker.
It can’t be connected successfully now either with WIFI, wire, USB or AUX. The red light just keep flashing indicating the connection issue.
Resetting the device didn’t work either.
It is an old device with little information on how to fix this.
Is there any way to check the root cause of the issue?
8条评论
Hi,
Have you tried resetting the device, you didn't say?
由 jayeff 完成的
Yes, tried that.
After resetting, the red light just flashed.
由 Shawn Chen 完成的
Seems can't do the firmware update.
Connected with USB not work.
由 Shawn Chen 完成的
@Shawn Chen
Did you try using the Control app?
由 jayeff 完成的
@jayeff
Yes, tried to but can't connect either.
The device can't connect in any way.
I have tried to reset and connect several times with no success.
由 Shawn Chen 完成的
显示更多的3条评论
