Disk Read/Write never gets above 20MB/s until I Run BlackMagic.
My late 2012 27” i5, without an SSD got very very slow. Disk Read/Write never gets above 20MB/s with normal computer usage until I Run BlackMagic, when disk is capable of hitting over 80MB/s . CPU use is minimal, ram is free and so is disk space.
Looks like something is throttling the system disk access, so anything i do is painfully slow. Apple System Diagnostics shows no errors with even the most thoroug scan, surface scan prooved no errors and so did fdisk -fy from single user mode. Heck, what else could I do except trying to run it from an external ssd installed system?
What is the version of OS you have on your system?
由 Dan 完成的
I'm on Mojeve now, but things heve been going downhill since previous versions. I did not pay too much attention to it as I've been mostly using it for leisure and my MBP for work for a couple of years, but I could use the bigger screem now but it appears unusable for any serious task.
由 Piotr Kocybik 完成的
