跳转到主内容
Released in 2017 the ASUS ROG Strix GL503VD is a high performance gaming laptop.
11 个问题 查看全部
Battery is charged but laptop stops on unplug
Hello,
I have an ASUS GL503VD laptop and I have an issue with the battery.
The BIOS shows that my battery is 91% charged but when I unplug my laptop, it just stops…
The percentage of the battery is always 91% and does not change at all.
What I tried :
  • Factory reset
  • BIOS reset/update
  • Driver reset/update
  • Open the laptop to unplug/plug the battery connector
Can someone help me to solve this please ?
Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
same issue however i replaced the old battery for a new one but still the same issue
完成的
What does your bios do if you are looking at it when you unplug the cord?
完成的
a new battery did not solve it for me
完成的
@caperry8 it just shutdown instantly
完成的
@Brian Beckford I don't think that will solve mine either ...
完成的
显示更多的3条评论
添加一条评论
2个答案
最有帮助的答案
@rtxx
Which driver did you reset?
Did you try uninstalling the Microsoft ACPI-Compliant Control Method Battery from Device Manager > Battery and then after it has uninstalled restart the laptop and let Windows "find" and install it again? Also check if it has the latest drivers installed. Right click on the entry and click on Update drivers and follow the prompts.
Create a battery report to check the status of the battery. When you have the report, compare the Design Capacity value versus the Full Charge Capacity value to determine it status. With a good battery they should nearly be the same.
这个答案有帮助吗?
得分 1
6条评论:
PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
2021-12-20 49 096 mWh 64 448 mWh
2021-12-21 49 096 mWh 64 448 mWh
2021-12-22 49 096 mWh 64 448 mWh
2021-12-23 49 096 mWh 64 448 mWh
2021-12-24 49 096 mWh 64 448 mWh
2021-12-25 49 096 mWh 64 448 mWh
2021-12-26 - -
完成的
And yes I've already uninstalled Microsoft ACPI-Compliant Control Method Battery and updated it
完成的
@rtxx
As the laptop stays on when the charger is connected, it appears as though it is a hardware problem on the motherboard, i.e. no power into or out of the battery.
What is the model number of the motherboard? It may be necessary to find the schematics for the motherboard and usually they are easier to find when you know the board number than just the laptop name and model number.
完成的
The model number is dabklmb28a0
完成的
@rtxx
Unfortunately I can't find any schematics only boardview links, which doesn't help as they only show the location of components on the motherboard.
Found this link which didn't solve the problem but maybe will give you some ideas of where to look.
It appears that you are not the only one with this problem.
完成的
显示更多的1条评论
添加一条评论
You should consider replacing the battery…
How old is the computer?
这个答案有帮助吗?
得分 0
1条评论:
The laptop is 3 years old.
I'll buy a new battery this week to try it
完成的
添加一条评论
添加你的答案
Rtxx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 56
总计 515
