跳转到主内容
加入维修社区 - 创建账户
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
IFixit Battery replacement issue
I recently purchased a replacement battery from iFixit for my macbook pro (15” late 2013, retina, 2.3 GHz quad core i7 intel chipset).
The old battery was well-beyond its lifespan and was swollen.
Replaced according to instructions, and was successful - upon initial testing and running, the computer and its battery worked fine and was visible in the battery display on the menu bar.
After a week or so, the battery is: 1) not charging, 2) not recognized by any of the system diagnostics or by the coconut battery app, 3) not showing up on the battery display on the menu bar.
I have: 1) reset SMC and PRAM according to Mac instructions (and other sources), 2) rebooted and re-checked, 3) opened the computer backing and checked the connection for solid fit and for any potential bad pins.
My questions: 1) is the battery bad? 2) is there a bad connector? 3) is there a bad resistor/fuse/circuit on the logic board?
Any advice on A) how to confirm any of the above, and B) what’s my next step/option for repair? Is it possible to get a replacement for the battery I ordered from iFixit? I would very much like to check the other potential problems before doing so - better to determine the true problem before re-replacing a brand new battery.
Thanks so much in advance for any feedback.
Happy Solstice, Kwanzaa, Hannukah, Christmas, and whatever celebration of winter and return of the sun that suits your cultural fancy!
Best,
Dan.
Edit: Here is the coconutbattery screenshot:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Take a snapshot of the apps main window and post it here for us to see with the charger plugged in 在已经存在的问题里加入图片
完成的
@danj I added the screenshot of the coconut battery app (assuming that is what you meant by the apps main window)
完成的
添加一条评论
1个答案
已选择的解决方案
Sorry your batteries micro-controller has failed, contact the iFixit store for a replacement.
这个答案有帮助吗?
得分 1
3条评论:
Do I need to replace the entire battery, or just the microcontroller?
完成的
@reddain - The whole battery is needed.
完成的
I greatly appreciate your help and informative advice... thanks so much.
完成的
添加一条评论
添加你的答案
Daniel Curewitz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 155
