跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Power/Sleep and Home Button Unresponsive
I have a iPod Touch 4g which has a cracked screen. I replaced it, and still didn't put it back. I attached the two wires from the screen to the iPod, and now the Power Button and touch screen are not working. I plug in my charger, and it goes to the password screen, and I can't slide it.
How can I fix this?
EDIT: The volume button also don't work :/
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Assuming that everything worked well before, the #1 culprit for malfunctioning electronics after dis-assembly tends to be dirty or poorly seated connectors. Clean everything well with a high-content rubbing alcohol and make sure the connectors are seated fully. If that all checks out, closely inspect each of the connectors and see if a pin was damaged. Good luck and let us know what you find!
这个答案有帮助吗?
得分 1
1条评论:
I tried this, and now the display doesn't light up anymore when I plug the charger in :(
完成的
添加一条评论
It is most definitely a damaged on/off, volume flex cable. There is a post elsewhere on this site.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cytonic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,010
