跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Screen won't turn on
So I have literally done everything, I've checked the battery the battery works, I've cleaned all the ribbon cables to make sure, I've disassembled it and everything nothing has corrosion on it everything is great and I cannot figure out why it won't turn on. There's absolutely no damage on the motherboard whatsoever or any other part of the internals for that matter. There's no visible cracks on the screen or inside of the system. I don't think there's a problem with the charging port because I will plug it in and it will heat up the battery as if it's charging. I also tested the battery to make sure that the battery works the battery works fine. I also plugged it into the computer and the computer recognize that something was plugged in but it didn't pull up anything/ it didn't pull up the switch as if it was on. There is no responsiveness from the screen whatsoever I'm also not getting sound I cannot figure out what to do.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Could of tried a jailbreak or Emmc is damaged. Try holding the power button down for 10-15 seconds
完成的
That's the thing it won't turn on. If I plug it into the computer and use tegrarcm it registers it just fine. And I tore the whole thing apart and the power button seems to be just fine there's no corrosion or anything on it. It's in pristine condition just like the whole inside of it is.
完成的
添加一条评论
1个答案
已选择的解决方案
Download a program called tegrarcm on your laptop or pc. Connect the switch to see if it detects it. If it’s in rcm mode it can cause a black screen.
这个答案有帮助吗?
得分 1
1条评论:
So it does appear to be stuck in RCM mode but what do I do after that? It's a version one Nintendo switch and I bought it off secondhand so I'm assuming somebody attempted to jailbreak it and it just got stuck. But what do I do now?
完成的
添加一条评论
添加你的答案
Dj Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 31
总计 1,265
