Screen won't turn on
So I have literally done everything, I've checked the battery the battery works, I've cleaned all the ribbon cables to make sure, I've disassembled it and everything nothing has corrosion on it everything is great and I cannot figure out why it won't turn on. There's absolutely no damage on the motherboard whatsoever or any other part of the internals for that matter. There's no visible cracks on the screen or inside of the system. I don't think there's a problem with the charging port because I will plug it in and it will heat up the battery as if it's charging. I also tested the battery to make sure that the battery works the battery works fine. I also plugged it into the computer and the computer recognize that something was plugged in but it didn't pull up anything/ it didn't pull up the switch as if it was on. There is no responsiveness from the screen whatsoever I'm also not getting sound I cannot figure out what to do.
2条评论
Could of tried a jailbreak or Emmc is damaged. Try holding the power button down for 10-15 seconds
由 daniel 完成的
That's the thing it won't turn on. If I plug it into the computer and use tegrarcm it registers it just fine. And I tore the whole thing apart and the power button seems to be just fine there's no corrosion or anything on it. It's in pristine condition just like the whole inside of it is.
由 Dj Brown 完成的
