跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Transparent rear panel, will it effect the camera?
I am interested in buying the new transparent back panel kit for iPhone 4s.
However i've read that changing the back panel will effect camera performance. For the ones more familiar with the iPhone's history will know that this was the reason the white iPhone got delayed, so i find it hard to believe a transparent panel will not affect the camera.
I want to have this panel (great work iFixit), but camera performance is more important to me.
I've found another back panel mod on the web and i am wondering what your opinion is on their statement that this mod will not affect camera performance. Personally i find this statement hard to believe.
In short: will a clear back panel affect camera performance?
Thanks in advance, Sander.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
I just converted my iphone yesterday with a transparent front and back. The first thing i noticed was the picture quality of the camera. the performance isn't hindered in any way, but because of the transparent plastic, the pictures are just a tad bit fuzzier than normal. it's hardly noticeable, though, unless you're looking for a difference. overall, i really like how my phone looks and the picture quality doesn't bother me at all. like i said, barely noticeable. also, the flash works fine as well.
这个答案有帮助吗?
得分 1
添加一条评论
AshD, can you post a pic of what you did? I would really like to see final product.
这个答案有帮助吗?
得分 0
添加一条评论
It appears that the protective backing on the transparent back panel does not remove completely and a small piece of it remains over the lens that has to be removed separately once you have removed the protective backing. Image quality will improve significantly once you have removed this piece.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,126
