跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Power button doesn't work
Hi, my MacBook does work absolutly fine when it’s turned on, execpt the power button. The button don’t react on any action.
I can’t do an SMC reset or anything else. To start the MacBook I have to open the buttom side an disconnect the battery. After reconnect the battery I plug in the magsafe adapter and the MacBook boots automaticly.
Is there another way or workaround. My daughter uses the MacBook sometimes for school and I don’t want her to open the MacBook.
Please excuse my bad english.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
To fix this problem, the MacBook must be opened. You can either take it to a repair shop, or
A} Replace the top case($200), guide here
or
B) Replace the keyboard ($19.99), guide for a 2013 MacBook keyboard replacement is available here
Replace an upper case assembly that includes the backlit keyboard compatible with the Early 2015 model A1502 MacBook Pro 13" laptop. Part #661-02361.图片
产品
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly
$98.99
Replace a damaged, dirty, corroded, or malfunctioning keyboard.图片
产品
MacBook Pro 13" Retina (Late 2013-Early 2015) Keyboard
$19.99
MacBook Pro 13" Retina Display Early 2015 上部机身图片
指南
交换MacBook Pro13'' Retina显示器 2015早期版本的上部机身
难度:
困难
3 hours
MacBook Pro 13" Retina Display Late 2013 键盘图片
指南
MacBook Pro 13" Retina Display Late 2013键盘更换指南
难度:
困难
2 - 4 hours
这个答案有帮助吗?
得分 1
1条评论:
@andrewsawesome - Best to verify they issue is the keyboard by using the power pads to by-pass the button. If the system doesn't startup with it then there is a different problem! Macbook Pro 2013 2014 2015 power pads
完成的
添加一条评论
添加你的答案
Benedikt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 349
