跳转到主内容
Repair guides and information for kitchen food scales.
27 个问题 查看全部
Why does my scale not read reliably or return to zero reliably?
Duronic kitchen scales KS865 - wheatstone bridge strain gauge-based balance.
The scales tare correctly, but when I place an object of known weight on it reads low. When I take that object off it does not quite return to zero. The scales have recently been dropped.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I found that the load plate (top part) of the scales had become slightly twisted in its mounting (through the strain gauge) to the base of the scales. This was causing the load plate to rub slightly on the base and make the readings unpredictable. By slackening the two screws that mount the load plate to the strain gauge, and realigning, I was able to get the scales working perfectly again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dan_6384856255 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 22
总计 124
