跳转到主内容
Valve Steam Controller (Steam 手柄)于 2015 年 11 月 10 日发布。型号为 1001。
How to repair/clean/replace the joystick?
Steam controller joystick feels like it has some obstructions on the upper lef hand quadrant and when playing a game, even if I hit the uppermost limits on this region the character starts to walk instead of running. If I push hard enough, the character responds and starts running. How can I fix it? Is there a way to replace the joystick if I can’t fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
According to the teardown, the Steam Controller is relatively easy to take apart with only a T6 screwdriver. You would need to reach Step 5 to get to the thumbstick (carefully unplug the ribbon cables on the trackpads before removing from the chassis). That should at least show if there are any physical obstructions causing the behavior you observed. Brush around the stick with a cotton swab dabbed with some isoprophyl alcohol.
Worst case scenario, the thumbstick is soldered to the motherboard, so it would need to be desoldered to replace it. I'm personally not sure which would be a suitable replacement module for Steam Controller.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Morales 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 229
