跳转到主内容
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
204 个问题 查看全部
I replaced my cracked screen; I checke
I removed the cracked screen and replaced it with the new one. Before I seated the screen onto the bezel, I checked to make sure everything worked and it did just fine. After I installed the screen it stopped working, I removed the screen, went through the process once more, the screen worked but stopped working when I put it in place. WTF!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
My thought is the connector or ribbon cable. If the connecter is seated correctly move to the digitizer ribbon. I like to see happy cables. Nothing bent sharply or wrinkled.
With the iPad turned on. You can hold the screen on its side. Dont put finger prints inside the digi screen…. While on its side carefully push on the ribbon cable. slightly adjust things and test the screen while its sideways. See if you can replicate it not working. If cables arent the problem it could be a bad digitizer. Also check to make sure nothing is touching the digitizer while its closed, a piece of glass, a screw not tight and touching back side of the screen. I have found all sorts of tiny crap that just barely touch the screen or ribbon and makes everything go crazy.
Good luck. Troubleshooting iPads can aggravating because its always something simple or chasing a bad part.
这个答案有帮助吗?
得分 0
1条评论:
Ok, checked everything and it looks good but now I am getting a message "unable to activate touchpad". I want to reboot; how can I do that without the touchpad?
完成的
添加一条评论
最有帮助的答案
Just to be clear, you replaced the actual LCD, not just the front panel/digitizer?
Either way, my first thought is that something is reading as disconnected or is touching something it’s not supposed to when everything is all closed up. I would check and make sure all your connectors are firmly seated, and that all of the cables are rounded, no hard creases where lines may be broken, or traces may become exposed and contact something they aren’t supposed to and nothing is getting pinched. I know the LCD cable is basically folded in half when the device is closed so i would inspect it closely.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
randy whedon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 34
