Worn pin is this fixable
Are burn pins fixable
Update (12/16/2021)
can this be fixable or is it garbage?
Yes. You can use something like the [关联产品丢失或禁用: IF317-054] and draw the new trace or put a dab of solder in the trace.
这个答案有帮助吗?
Thank you but will this be able to read the games?
It should as long as the game port deck (or whatever it is called can’t think of it) is in good condition. Just make sure to scrape off any corrosion before applying.@mmusk818
alright thank you
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 105
