跳转到主内容
加入维修社区 - 创建账户
型号 A1418 / 2013 年末机型 / 2.7 GHz 或 2.9 GHz Core i5 处理器,或 3.1 GHz Core i7 处理器
Replace iMac Late 2013 screen with screen from iMac Late 2012 model?
Hi everyone,
I unfortunately damaged the screen of an iMac Late 2013 21.5” when replacing the HDD with an SSD and upgrading the RAM, and I’m looking around for replacement screens.
I see that replacement screens are more expensive than an actual iMac from that generation, so I’m exploring the option of buying a Late 2012/2013 Mac, taking the screen off of it, and placing it onto my upgraded iMac instead.
My question is, will an Imac Late 2012 21.5” screen be compatible with an iMac Late 2013 21.5”? (e.g. Will the ribbon cables be different even though the screen looks the same externally?)
Thank you all!
JJ
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
The 2012 & 2013 21.5 iMac’s use the same display assembly!
So you technically can swap over the displays from the two systems. But before you go down that direction see if this works for you 2012/13 21.5” iMac Display Assembly, Grade-C, Apple P/N 661-7109, LG # LM215WF3 (SD)(D1) its a lot cheaper than buying another system just for the part! They also have better quality units at a higher cost as well.
这个答案有帮助吗?
得分 4
2条评论:
Thank yo Danj for the confirmation and the link! I'm based in Australia so the link you provided still converts to a price that's higher than what a late 2012 imac 21.1" goes for on Facebook Marketplace / Gumtree.
JJ
由完成的 分享
@cocooloccoo - That still works! Where in Australia do you live? Is Fosters still in quart cans? ;-}
由完成的 分享
添加一条评论
Hi, Will a 2015 screen work on the 2013?
这个答案有帮助吗?
得分 0
1条评论:
@jurgenphot29292 - Sorry that’s to far a leap. The mid 12 and 13 use the same display.
由完成的 分享
添加一条评论
What about 27” iMac are they the same?
这个答案有帮助吗?
得分 0
4条评论:
Which series (year) is your system and the part?
由完成的 分享
Hi Dan first off thanks for taking the time to reply. I am running a 27inch late 2013. 3.2 Ghz Quad core intel i5 with a Nivdia GeForce GT 755M 1GB.
My screen is cracked in several places. I wanted to know if I could use a 2012 screen from another iMac.
Many Thanks,
Tony
由完成的 分享
@tonyveart - Both use the same display assembly: Apple P/N 661-7169 or 661-7885; LG P/N LM270WQ1 (SD)(F1)
由完成的 分享
Thanks for that Dan finally got round to updating my 2013. A secondhand 2012 screen fitted straight in no problems.
由完成的 分享
添加一条评论
What a about a mid 2011 27 inch screen on a late 2013?
这个答案有帮助吗?
得分 0
1条评论:
Sorry totally different screens. I have a late 2013 which is the slimline version where the screen is all one piece and glued on. The 2011 is a much thicker model, the glass being seperate from the lcd. The glass being held in place by magnets and the lcd held in by screws.
由完成的 分享
添加一条评论
添加你的答案
coco 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 76
总计 4,242
