跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Boot loop when trying to load any OS
So the other day I found a 2010 macbook pro 15 someone threw out (they were nice enough to include the OG charger, 16gb of ram, and a DP+USB to DVI+USB OEM cable). However it seems to boot loop whenever it tries to load an OS.
The OS previously installed boot loops when it gets toward the end. If I try to use a High Sierra install USB, it will freeze, crash, and boot loop after the first page. As soon as I press “next” after the first page where you select language, it would just crash. The SSD I was going to try to install macOS had Win10 previously on it, which does load but as soon as the spinning circle appears it freezes up (and sometimes boot loops).
I’m wondering if this is the case of a dead GPU, I’ve seen a 2010 15in that had a dying dGPU but that thing would kernel panic in the OS instead of just boot looping outright. Has anyone seen this kind of problem before? Is it a dead GPU or is it something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Are you able to boot up using Target Disk Mode (TDM) ? Disconnect the battery following this guide 2010年中期MacBook Pro 15寸 Unibody 电池更换, then press and hold the power button for 15 secs to fully drain the logic board. Now plug in the MagSafe charger and quickly press the T key to enter into TDM.
Reference: Mac startup key combinations
TDM bypasses POST and leverages Intels HD Graphics which is within the CPU bypassing the discreet NVIDIA GeForce GT 330M GPU logic. You should see a FireWire Icon on your screen do you?
这个答案有帮助吗?
得分 0
2条评论:
Yes, target disk mode seems to be working. It's probably the faulty GPU/capacitor for the GPU then?
完成的
@watercannons collaborations - Yes, you have a NVIDIA GPU issue
完成的
添加一条评论
添加你的答案
watercannons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 542
