Laptop headphone combo jack has detected an output, but no input.
I have a ASUS laptop that i have been using for years with no problem. For no absolute reason the headset that i use has a microphone (the SteelSeries Arctis 3 ) and it has been working well, now the laptop only detects the headset as an output with no input, which means that i am not detecting the headset microphone that i intend to use, which is a bad thing because i use it a lot for calls.
6条评论
Hi @lockxh,
What is the model number of the laptop?
Just verifying that you checked the settings in Control Panel > Sound > Recording to see if the microphone is detected?
If so can you use another headset to verify that your headset is still OK?
由 jayeff 完成的
@jayeff i have checked the headset on a different laptop and other electronics, it works fine
由 Lock 完成的
@lockxh
If it is a faulty combo jack, then knowing the model number will help to find the correct replacement part.
Did you check the setting in Control Panel as suggested?
由 jayeff 完成的
First off, congratulations for making your Asus last that long. In my opinion most don't make it beyond 6 months. I call them Walmart Brand.
Anyway the port in your Asus is probably worn. If your jack works on other devices but not the Ausus I would say it's the Asus port. Try another microphone if you can beg, borrow, buy or steal one
由 Kali Meli 完成的
@jayeff A542u FDM125T, control panel shows nothing about the microphone
由 Lock 完成的
显示更多的1条评论
