跳转到主内容
The Surface Book 3 13.5" is a hybrid laptop/tablet manufactured by Microsoft and released in May 2020.
Rebooting when connected to surface dock locks up
Hey everyone,
Super interesting issue. Previously it would reboot just fine when connected to the dock but now it just stays on the windows/surface logo screen. It reboots perfectly fine when disconnected from the dock.
Any idea what it could be?
Troubleshooting already done:
Uninstalled the surface dock firmware (did not delete the driver) and plugged back in.
Tried to manually update the firmware on the surface dock and I don’t see a version number change.
I’m going to reach out to Microsoft as well but wanted to put this here in case anyone has had this issue before.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Update: It will reboot if disconnected from both external monitors. Going to try to reboot with one attached.
完成的
Narrowed the problem down further: it is specifically when the lid is closed/integrated screen is off that it gets stuck on the logo screen.
完成的
添加一条评论
1个答案
已选择的解决方案
Found the problem: Check Point Endpoint Full Disk Encryption doesn’t allow for a surface to reboot fully with the lid closed. It always stops before it gets to the pre-boot screen. I tested on 2 other Surface Books we have and the result was the same.
To fix it: We removed pre-boot and FDE and replaced it with Bitlocker. Reboots just fine now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lee Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 678
