跳转到主内容
加入维修社区 - 创建账户
FLIR FX 是一款由 FLIR Secure 推出的具备无线 Wi-Fi 监控功能的高清安防摄像头。型号为 FXV101-H。
My surveillance project, I understand just enough to get in trouble
So the project I'm working on, I'm using 4 cameras, I have purchased a ZOSI H.265+ 5MP Lite CCTV DVR 8 Channel Full 1080p, it doesn't come with a hdd or camers, so I was going to purchase
Western Digital 4TB WD Purple Surveillance Internal Hard Drive HDD - 5400 RPM, SATA 6 Gb/s, 64 MB Cache, 3.5" - WD40PURZ
and
ZOSI 1080p Dome Security Cameras (Hybrid 4-in-1 HD-CVI/TVI/AHD/960H Analog CVBS),2MP Day Night Weatherproof Surveillance CCTV Camera Dome Outdoor/Indoor,Night Vision Up to 80FT
I just don't know if this will work, am I missing something? My knowledge level is probably a minus something out of 10, could really use help. Thank you everyone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Oops sorry I meant to add,
Expense is an issue which is why the equipment isn't the most expensive
由完成的 分享
添加一条评论
1个答案
The only issue is the size of the HDD. I can't find any info on that but I have not seen 2.5" surveillance drives so it is a good assumption it takes a 3.5" drive. So, you should be good to go. Check your manual.
Since you are using the same mfg cameras, there should not be an issue with that.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil A Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 608
