跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Samsung TV.
Samsung TV Causing Pixelation
Had A Samsung TV in Bedroom, worked fine for ages then it started pixelating on some channels even though the TV said the signal strength was good. Did lots of checks on aerial plugged in another TV from another room in the bedroom and it was fine. Decided it was the TV bought another Samsung and it did the same so returned it. Bought a cheap Blaupunkt and it has been fine. A couple years have passed and I have been given a Samsung TV for the study. Plugged it in and now the Blaupunkt in the bedroom is pixelating on some channels. The Samsung doesn't even have to be plugged in to cause this just the coaxial plugged in. Any idea what is happening? The Panosonic in the lounge is fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is due to signal degradation. you need to check all the line for damage. also looka t the ends for corrosion and clean. you probably have a splitter and this is the most likely culprit. these you just replace.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Parker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 958
