跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
Rounded pentalobe screw extraction
So, I'm repairing a phone (iPhone 11 Pro max) but the phones been repaired so many times the pentalobe screws have worn and I can't extract it. I've youtubed it and things but I think I need an extraction tool. Anything on the market?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’ve dealt with this issue a few times with eBay phones, Some ways I dealt with rounded bottom screws was to superglue the bit to the screw and let it sit there for like a day and that trick worked. More destructive ways are to well get a small drill bit and drill the head of the screw off. Or the final way after everything fails is to separate the screen from the plastic rails that run along the side of it, keep in mind this will most likely destroy the screen but you’ll have access to the internals but it will leave the hole plugged up with a screw.
这个答案有帮助吗?
得分 0
1条评论:
I was thinking something along the same lines but with a turbo torch and rods but you risk over heating components
完成的
添加一条评论
添加你的答案
Alex Asquith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 198
