跳转到主内容
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Tablet won't turn on
Whenever I try to turn on the device it just blinks the notification light 3 times. I’ve tried charging it but no luck. Can someone help?
Update (12/03/2021)
Figured it out. For one it was 5 blinks, not 3, and also you just need to charge it longer it seems. I recommend
90 minutes - 2 hours.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would recommend you try a different cable and/or wall wort charger that is a 2a rated one. but it is most likely a cable issue. some use 2 paths of power to charge and if one path is damaged you get slow/no charging.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack Swallowell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 162
