跳转到主内容
The Plantronics Voyager Legend is a wireless, Bluetooth enabled headset, which is compatible with most cellphones available on the market. Originally released in September, 2013, this device is still popular among a wide variety of users.
22 个问题 查看全部
Do battery replacement instructions also work for Voyager 5200?
The Plantronics Voyager5200 looks almost identical but is in fact different (Rtings has side-by-side pictures). Do the battery replacement instructions for the Legend also work for the 5200? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
basically yes they are almost identical. Just be sure you get the right battery with the right leads.
这个答案有帮助吗?
得分 0
5条评论:
Did you actually perform a battery replacement on the headset? I am sure that they are identical from the inside, but the fastening of the case looks quite different, if you look at the pictures.
完成的
@jastram I did it on the new one. They are the same type of pressure snap clips so be gentle when you separate.
完成的
@jastram
https://www.youtube.com/watch?v=oXuHwYJv... (Legend)
https://www.youtube.com/watch?v=odVpATQO... (UC)
Hope this helps a bit more than me just saying it's very similar!
完成的
Those videos are useful, thanks. In fact, they show that disassembly is easier than with the Legend.
完成的
@jastram not a problem. if this answered your question please chose an answer but if you have issue you can still come back and ask
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 27
总计 295
