跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
How to fix trackpad
I know trackpads on this kind of macbook pro are known for geting stuck BUT,
How do i fix mine???
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I would stat off by taking it out so you can properly clean the trackpads case edge and the trackpad as well.
Update (02/07/2022)
@beanman56 - Make sure the click switch is not damaged, you should be able to press on it to get it to click. I use a small coin placed on top so the pressure is even.
If that works then after you’ve put it back in you should only need to adjust the setscrew
The resting tangs should be on a small piece of felt (dark area inter it) give it a 1/4 turn clockwise at a time to raise it up so it engages sooner. Do be careful as its a bear to get rethreaded if you go to far.
这个答案有帮助吗?
得分 2
2条评论:
@danj I have cleaned it NOW its down doesn't click or come up
完成的
@danj - I tryed what you said in the update, nothing!
I think i need the top case then
完成的
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 133
