跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
277 个问题 查看全部
MacBook Pro 2017 13 - black lines on the bottom of display
https://discussions.apple.com/thread/250...
I have this exact problem and Apple is not offering any help. Their display replacement program only includes the 2016, not the 2017 model.
What I want to know: Would replacing just the flex cable fix this? If so, can the cable itself be replaced, or does the whole screen need to be swapped out? And, if it is only the cable, does iFixit sell the right one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The Apple discussion space allows the collective Mac population to have a place to discuss things. Sadly, Apple tends to yank technical issues (as well as the people with proper answer) like yours as it brings quality questions out into the public space. The people who know what’s truly going on are not there! They are here!
So lets first define your issue: This is a scan issue within the display. This is not a cable issue so replacing any won’t fix this. FlexGate is when the backlight LED’s loose power giving a stage-lighting effect
So what is this scan issue?? Apple altered the display design so part of the displays logic is placed within the main case so Intel CPU heaters! Kills the T-CON logic.
Sadly, you need a new display assembly to fix this and to prevent it from happening again get this app TG Pro so you can monitor your systems thermals (and push it if needed).
I also recommend you clean the dust and debris out of your systems fans and heat sink fins so your system is getting the needed cooling, and lastly don’t block the vents! Don’t use your system on a bed or rug which suffocate your systems vents.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JoyfulRebellion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 385
