跳转到主内容
Fully portable sequencer and synthesizer from Teenage Engineering, which can also produce live visuals and control DMX equipment.
4 个问题 查看全部
Where do I get replacement encoder dials?
Encoder dials don’t seem to be available and I’m missing two thanks to lending it out, please help
Update (09/12/2022)
3D file for replacement encoders with space for a 6mm DIAMETRIC magnet https://drive.google.com/file/d/1-O0g11s...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Hey dude, did you ever figure this out? I have the same issue and can't find out where to get a replacement. I've even tried buying a broken one on ebay to replace with but other people keep on out bidding me
完成的
添加一条评论
2个答案
已选择的解决方案
I did, but there is a catch.. I ended up buying a 3d printer, modeling the encoder myself, printing it, figuring out that I needed a diametric magnet, and going through some troubleshooting.
So now i have 2 blue dials, but they work perfectly.
I'd be happy to make some more.
atom8oh insta
这个答案有帮助吗?
得分 2
5条评论:
Could I get the Stl. file?
I have the same problem.
完成的
Appreciate the file, what magnet dimensions did you use exactly? I'd guess by the file that it's 6mm x 1.5 mm but that does not appear to be a common find...
完成的
Would I be able to purchase some screen printed knobs off of one of you kind fellows?
完成的
Im keen just lost an encoder
完成的
添加一条评论
I 3D printed a replacement but the magnet I used sends the encoder crazy so i cant use it. I might need to hget a bidirectional magnet :(
这个答案有帮助吗?
得分 0
2条评论:
You for sure need the right type of magnet. diametric magnets are what you need
完成的
I have the same issue, lost all 4 knobs in a car accident. Would I be able to buy some of the screen printed ones off of you please??????
完成的
添加一条评论
添加你的答案
semilogical 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 786
