跳转到主内容
Miposaur is a robotic dinosaur made by WowWee in 2015 and its model number is OKP0890. This guide will provide resources for and information on repairing a broken Miposaur.
5 个问题 查看全部
Battery holder is corroded
Battery holder is corroded can I get replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Can you not clean it of corrosion? A small metal brush should be able to clean all the corrosion from the batteries out, and then it should be fine.
I haven't been able to find anyone that has the battery cartridges in stock. You could always change it to a rechargeable battery pack. Wowwee's website has those in-stock.
完成的
添加一条评论
1个答案
mix some baking soda with water and using a q-tip dab it and rub off the corrosion. when you get it clean than apply some dielectric grease and it shouldn’t corrode again at least not for a very long time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
June Page 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 98
