跳转到主内容
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
159 个问题 查看全部
Bluray drive keeps spinning up with no disc every 10 minutes?
Hey if anyone can help. Bluray drive keeps spinning up with no disc every 10 minutes ?
I replaced the Drive and swapped logic boards. I think some sensor is not working correct. I am also unable to turn the console off.
What I have worked out is if there is a disc in the drive it seems to work and operate as normal.
Does anyone know how to fix it ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hey @tomchai you seem to be a guru, Any ideas
完成的
添加一条评论
1个答案
最有帮助的答案
Does it happen predictably every 10 minutes? If so, I guess some sensors are latched triggered and the drive is cycling to try to clear that. The sensor is ignored when the disc is loaded so it doesn’t happen with a disc inside.
这个答案有帮助吗?
得分 1
3条评论:
Hey Tom, thanks yes it does happen predictably. On first boot up it spins up loud at full speed. Then roughly at the same intervals. I haven't timed it. Is the sensor on the daughter board ?
完成的
@kgm316 From what I remember, the sensor is on the roof of the drive enclosure. If you have replaced the whole mechanical part of the drive, maybe some front end circuitry on the daughterboard is having issues.
完成的
I had this problem. had to replace the disk sensorfrom the underside of the drive from the original to fix this problem
完成的
添加一条评论
添加你的答案
Kelly Moore 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 66
