跳转到主内容
Repair guides and disassembly information for Lenovo's 3rd-gen ThinkPad X1 Carbon laptops.
7 个问题 查看全部
How to replace my screen sensor for it being open/closed
I am going to say this isn’t a popular issue but when I close my lid the screen stays on. I am very techy and have already checked to make sure it sleeps or shutdowns when the screen is closed. Being as the X1 Carbon Gen 3 is kind of like a ultra book it is extremely complex inside and I need to repair it without breaking it. If you have a resolution please and thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @davclay ,
Try waving a magnet over the hall effect sensor to see if you can make the display turn on and off.
If it works you may have to check that the magnet in the lid is still in position.
If it doesn’t work then check that the hall sensor cable (part # 01AY250) is securely connected. If it is then the sensor may be faulty.
Here’s the hardware maintenance manual for the laptop. Go to p.66-67 to view the location of the sensor and cable connection.
这个答案有帮助吗?
得分 1
添加一条评论
There is a little magnet that falls out of it’s holder, you should be able to take off the bottom and find it and hot glue it back were it is supposed to go. be sure the wires are all back in their channels before you seal it up again.
you can test the sensor by running a magnet along the top of the screen. about 1” to the left of camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 51
总计 694
