跳转到主内容
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
83 个问题 查看全部
Washer not starting but powering on. We removed and cleaned the contro
When we turn on the washer, the start button will not work. We cannot turn the knob to a different setting or modify any of the other settings. We followed a YouTube video to run diagnostics and found that there were no saved error codes. Only 888 was on the display and off the buttons seemed to work in the mode.
We than proceeded to take off the lid to access the control panel to clean the contacts on the control board. We hooked everything back up and are still experiencing the same problems. Does anyone have any suggestions? Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi @naem08 ,
Not being able to physically turn the cycle selector knob is a concern, as it is connected directly into the electronic control board. Hopefully the mechanism in the control board is not jammed
Here’s the tech sheet for the washer.
Go to p.11 and see the Troubleshooting Guide > Won’t Start cycle causes and checks.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much for the guide! This is very helpful!
完成的
添加一条评论
does the screen interface get any power? did you try a reset? and self diagnostic?
https://www.youtube.com/watch?v=GjY2OhTW...
这个答案有帮助吗?
得分 0
1条评论:
Yes I did a self diagnostic test and no error code came up. The dryer started working the next day when we powered it up after cleaning the control panel.
完成的
添加一条评论
Cleaned the control panel with alcohol and waited to power it up the following day.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nae M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 68
总计 2,819
