跳转到主内容
微星所制造的笔记本电脑的维修和支持指南。
269 个问题 查看全部
GF63 8RC-264US service manual
The LCD in my laptop seems to have gone out, but I doubt it since I had to secure the hinges and used JB weld for this time( just to see the outcome) and somehow the LCD had a slight pink tint to the video and then went out. I plugged in an external monitor and no video. So I’m undecided what this could be. MSI are jerks with giving out anything like a service manual and this is pretty unfair IMO since I cannot afford to have them fix it unless it was free, its not.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi,
Long shot but try starting in safe mode just in case it is a driver problem.
No video on an external monitor as well indicates a motherboard problem. (presumably you remembered to press Fn + F2 to switch the display from the laptop to the external monitor).
The laptop has two graphics adapters i.e. one discrete Nvidia GPU and an Intel iGPU. It would be unusual for both to fail so that’s why it might be a motherboard problem.
With the laptop turned on and hopefully booted into the OS, try shining a torch at an angle close to the laptop screen to see if you can detect any images at all. They will be very faint if they are there, so trying this in a darkened room may help to see them.
If you can detect images then there is a backlight problem, but this is only for the laptop screen and not the external monitor.
What is the laptop’s motherboard’s board number? (printed on motherboard itself). The best way to hopefully find the schematics for the motherboard is to search for (insert motherboard board number) schematic, as these may be required to find out what’s wrong.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Greg Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 282
