跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
Keyboard and trackpad not working
Macbook Pro was working fine last time I used it a few weeks ago. Its been powered off since. Started it up today and the keyboard and trackpad dont work. Connecting external keyboard and mouse work fine. Cant boot in safe mode to troubleshoot, again because the built-in keyboard doesn’t respond.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Apple loves making things complex!
If I remember correctly the TouchPad logic is also the USB driver logic for the keyboard. So I’m suspecting you might have had a spill or you used some cleaner which seeped under neath damaging the logic board. Here’s the needed part MacBook Pro 15" Retina (Late 2016-2019) Trackpad and here’s the guide to put it in 2016年末带Touch Bar的15寸 MacBook Pro 触控板更换
While you’re in their check the keyboard cable connector for any corrosion
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.图片
产品
$54.99
这个答案有帮助吗?
得分 0
2条评论:
Thanks, I'll check in to this. There were no spills or anything and I dont use any cleaners on the keyboard or track pad. Its just odd it all of a sudden stopped working.
完成的
@sharkdiver72 - In that case the Touch Bar cable would be suspect. What can happen is the batter swells up and presses on it damaging it MacBook Pro 15" Retina (Late 2016-2019) Trackpad Cable. That was less of a problem in series.
完成的
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 283
