跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
Broke Touch ID, how to disable it functionally?
I dropped a new iPad Air 4. I broke Touch ID, I don't need it, but the power button began to warm up excessively, turned off Touch ID completely, but still the button warms up. I note that the power button warms up only if you turn off the screen, that is, lock the screen, if the screen is on, it does not warm up, and as soon as I turn off the screen, it starts, and the battery also eats! Is it possible to completely functionally disable Touch ID, or is it possible to physically disable it, but to make the power button work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
9条评论:
Hi! I’m having exactly the same issue, have any of you worked it out ? I really don’t want to pay 450 bucks at my Apple Store :/
完成的
I'm having the same problem, did you find a solution? My battery is draining so fast because of my cracked touch id button :(
完成的
I haven't solved the problem in any way, but I'm thinking of opening it and physically disconnecting it from the board, I don't know if it will help or not
完成的
your solution gave me the idea to totally break it, thanks!
完成的
Well, IPAD Air 5 is my first apple device after ipod touch 4.
In which i was able to change battery and display
And now i have broken IRREPLACEABLE BUTTON WHICH HEATS UP AND DRAINS MY BATTERY?
It was like such a lite hit…
I suppose apple fan will say I should buy pro version with face id.
完成的
显示更多的4条评论
添加一条评论
2个答案
Comes complete with aftermarket home button. (Without fingerprint functionality)
https://store.ifixit.co.uk/products/ipad...
这个答案有帮助吗?
得分 0
1条评论:
We're talking Air 4 here, not regular Ipad 4
完成的
添加一条评论
Go to settings>Touch ID and password>and disable Touch ID
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amur Tar 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 69
总计 1,531
