跳转到主内容
加入维修社区 - 创建账户
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
ASUS X555QG Screw Sizes
Is there any X555QG documentation on where the screws should be placed? I lost track and now I'm scared of breaking something inside.
I have
4x 9mm
and 6x 11mm.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @banesrb ,
I couldn’t find any information regarding the locations of the screws in the laptop but here’s a list of all the screws that are used.
There are no 11mm screws in the parts list so presumably they are the M2*12L (12mm) screws.
Perhaps you could use a thin wire and insert it into the screw holes and then mark the wire so that you can measure the depth of the hole. A difference of 3mm between the screw lengths should be easy to discern
这个答案有帮助吗?
得分 2
1条评论:
I guess this will be close enough, thank you.
完成的
添加一条评论
添加你的答案
Bane 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 14
总计 1,115
