Screen going on randomly
On my A1502 if i connect to hdmi i can see video and computer works fine. Some times the lcd will come on then shut off within a few seconds. I dissasembled the screen and check the display cable. It looks ok. Anything else i should check?
When the screen is black shine a flashlight though the lids Apple logo acting as a backlight. Are you able to see the faint images of your desktop and its icons?
由 DanJ 完成的
Sorry i should of said that. I tried that and no image. I checked the backlight caps and no 48V. I also wanted to note that there is no water damage on this. Also that inductor by the lvds connector has 0V as well.
由 Dan 完成的
Slight correction the connection is not LVDS any more (unibody) its iDP signaling used in the retina models (early versions it was called eDP). Similar cable but different just the same.
由 DanJ 完成的
@Dan No backlight and no image but external monitor works? Sounds like a firmware problem. Did this happen out of the blue?
由 Chris Stables 完成的
@imicrosoldering - Why would you think this was a firmware issue?
Remember the 13" Retina systems use the CPU's intergraded graphics engine (no discreet GPU). So the data from the GPU is the same for the internal and external displays. This is likely a MUX logic issue. But we should first make sure the simpler issue is removed (bad connection)
由 DanJ 完成的
显示更多的4条评论
