跳转到主内容
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
19 个问题 查看全部
Can I transfer the "guts" into a Pocket Watch case?
I would like to convert a Galaxy Watch 4 into a pocket watch, I currently own a Watch 4 Classic, but I think the Watch 4 without the physical bezel would work better. But before I spend money on one, I wanted to see if it would be possible? I know I would need button holes made. But other than that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
While I can't answer your direct question, I did have a friend make a new case of his Apple Watch for his wife as she wanted a belt strap watch as she was a wood worker and a watch on the wrist would get in the way. It came out quite well! Using a small CNC system.
完成的
添加一条评论
1个答案
you can as long as the back is also clear glass or migrate the current back to the new frame. if you don’t you lose blood o2 and heart rate etc features. also make sure you use the right MM size frame for it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bobby Harrell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 591
